I have tried to create a brick-breaking game (arkanoid-style), but objects are deleted before colliders bounce off them - this means that my ball will go straight through the wall on first contact rather than bouncing off layer by layer. Is there any way to sequence the deletion to happen after the bounce?
It is a great idea to do an arkanoid game indeed! Indeed Candli does delete objects before collisions that would trigger a deletion, as otherwise it is very hard to have a character collecting elements for example.
For the brick-breaking game, this is a problem. It could be solved by having variables in object instances. This is not supported yet, but I think it is a very useful feature so I’ll work on it right now. I’ll keep you informed of the progress.
With these, you can just create a variable “block needs to be destroyed” (make a drawing for it ;-)). Specifically, create the following two rules (in that order):
When var = 1, destroy block.
When colliding with ball, set var to 1.
This works because Candli evaluates the rules from top to bottom.
