I have set the gravity to Jump and Run. Nevertheless, my character moves very slowly and floats. How can I change this?
This is because your character is gigantic! It is more than 15 meters high! As gravity is about 10 m/s², if your object is big, visually it would seem to accelerate less.
If you scale down everything in your level, the problem will be solved!
