Spinning dice in the air
How can I make a cube rotate 180° in the air and then land on the other side? I want to recreate the game “Geometry Dash”.
Hello!
Thank you for your question. To make a cube jump and spin, you need to add a vertical velocity and an angular velocity when the jump key is pressed. Don’t forget to enable the cube’s rotation, make it a dynamic object, and set the friction to zero. I have created a small test game here:
Have fun with it!
We both have the same names… hmmm…
ja… then who is the REAL Julian?
The two of us? It could work
